I like to change my decklid dampers because they are not strong enough to hold the decklid.
I found some OEM parts which look a bit different but they would fit.
The total lenght is 415 mm, expansion is 160 mm and they are available from 400 to 800 nm power.
Does somebody knows the correct pressure which is necessary to hold the decklid. I tried 400 nm parts but they are not strong enough. I will try 800 nm models when I will get them at the end of the month but I am interested to know the correct data.
