not much speed difference it is a little faster, but the old motor sent the window up in fits and starts ( various speeds ) this motor is constant in speed. I do not have a part number but again the motor is from a 3 door MK2 Punto, the 4 door car has a motor with a smaller diameter shaft.
There must be salvage yards where you are with these kind of cars?? if not let me Know. I will then chase up a part number for you. Peter.
