Originally posted by jack deryke:
Stock neoprene seals rapidly deteriorate into hard plastic that crack....
The stock timing chain often wears out in 20K miles on a 351-C with those enormous, heavy valves. It should be changed to a much stronger roller-type chain; this will allow your mechanic to reset the cam to straight-up timing. Ford was forced to retard the cam 4 degrees in '72 for smog....
..., I suggest adding a removeable rear crossmember to the car so the pan can be dropped next time without pulling the engine....
Jack, sorry for pulling out parts of your post and calling them "quotes," but I wanted to focus on three (3) questions:
(1) My mechanic said he can change the neoprene seals without doing the entire valve job by using special tools and pressurizing the valves, reducing significantly the labor and cost. His thinking was because the engine is really strong already and not smoking or showing any other signs of fatigue, there is no need to do a valve job, with the associated expense. Ever heard of this procedure? Any opinion?
(1)(a) My mechanic said his machine shop owes him some favors, and he owes me some favors, so if I elect to do the valve job, he can get me my choice of free porting or free polishing. Can you give a recommendation in this regard please? Which is better given a choice. I want relaibilty 1st, power 2nd, mileage 3rd.
(1)(b) My 351-C is not pinging on local high octane, but he said we could get the hardened valves or valve seats for pretty much the same cost. I am not sure what all this means, or whether it is worth it. Any clues you can provide will be appreciated.
(2) I sort of understand that there are three (3) positions the cam/valves/roller timing chain can be set at. 4 degrees retarded as per the factor after 1972, straight up, and 4 degrees advanced. I read that 4 degrees advanced will result in straight up valve timing after the chain stretches after the break-in period. He said the double roller timing chains stretch very little. I'm wondering what is the difference if I go with a double roller timing chain and straight up timing or with four (4) degrees advance. Suppose I go four (4) degrees advance and the chain does not stretch as much as I thought? What will the engine run like? What's your recommendation?
(3) A Pantera guy who's owned four (4) Panteras said he 'made his own' removable engine cross-member. Can you tell me how this is done, please.
Thank you. My mechanic was impressed that I asked these questions and asked a lot of questions about you. Which, of course I only know what I've read, so that's what I told him. He's impressed. Been a mechanic for 26 years, worked for dealerships, self employed, small shops, big shops, $250,000 in tools. He was impressed. Kudos, Jack!
