did you use the poly bushings? Mine started rattling after changeing to the polurethane bushings. That could be the cause of the noise you are hearing.
marlinjackThe Machinist #5723 AMARGOSA MACHINE 'Running on Empty- Middle of Nowhere'
...Been there, fixed that! It's one or both of the coolant tubes hitting against the front 'Anti-Sway Bar'! Just wrap a piece of heater hose about 3" long around the sway-bar, at that point. Silence!!!...
I had the same problem. drove me crazy. I checked the front end, steering etc. turned out to be the Battery hold down was loose and the battery was bouncing. tighened it..no more noise. Hope it helps
I found my coolant pipes hit the floor and made a small clonk. Also one of my Koni shocks had failed and made a big clonk. I put some rubber around the pipe and got Koni to rebuild the shocks.
(There is a fault with the original Koni shocks that makes them go stiff).
