Originally posted by Bosswrench:
Aluminum anywhere there's coolant in contact causes the same problem. But radiators are made of thinner metal so problems with corrosion show up sooner. With reasonable chemical care, nothing bad will happen. My Fluidyne aluminum rad is now 13 years old and cools fine with no leaks. That's with aluminum heads and water pump as well. But we don't have corrosive water here in N NV either.
Also keep in mind that ALL Corvettes, Z-28s and Ford Mustangs sold since about 1990 have had aluminum rads, cylinder heads and water pumps if not engine blocks. You're in Europe: Mercedes, BMW and Porsche also have had aluminum in direct contact with coolant for decades. And the forums for those cars have few posts about dissolving engines. But those owners mostly use anti-corrosion additives and sacrificial anodes in their coolant.
Why do giant car mfgrs use aluminum radiators? Because pound-for-pound, it works far better than anything else; they're about 40% of the wt of directly comparable copper/brass rads. Extra wt sucks up power and fuel.
So it should be ok to use the stock copper radiator with aluminium block and heads then?
