Dunno what diameter they are, but you can measure them after removing. They are NOT 5" dia, though. There is a complex cage in back of the speedo/tach held on by two thumbscrews. Remove the thumbscrews in back and the instrument comes out the hole leaving the cage in place. Then you can unplug wires & bulbs. The speedo cable screws on.
