I built my car for open road racing. All of the power comes at high RPM's. If you will be using this for the street I would suggest a slightly more balanced setup. You have my build. I would also recommend mounting the turbos low on the sides of the motor. This would be much better for weight distribution. I would think this impossible with the stock fuel tank. Run an intercooler also if you can find room. Good luck with the project.
