Who has pics of polished heat shields installed on the underside of decklids? I'm going to install a shield and am not sure if one piece or 4 inserts would be better.
Heat is not an issue in my case. I have 180's and have never had a problem with heat damage. This is for asthetics only.
If I use 4 pieces, I would have to use a high temp adhesive. How high would the temp rating have to be? If I use one large piece, I could screw it to the ribs.
Suggestions? Pictures?
Will
