I'm having what I consider an issue with my heater core, but it could also be a known issue with Panteras. As a new owner, I have nothing to reference if this is normal or abnormal.
When I turn on the heater the air blows at ~100 degrees F. After 1-2 minutes the air temp starts to drop and finally settles around 70 degrees F. Now 70 degrees isnt "cold", but it's certainly not very warm in the Colorado winter.
Any thoughts on why this is happening or how to fix it? What happens if the heater input/output tubes are swapped, can that cause this problem?
Sometimes, if the manual valves are left closed too long, or maybe if only one valve is used, trapped water, silt & antifreeze in the heater core seems to form a type of green jelly that blocks things up. It's a good idea to purge the cores by opening the valve(s) every year or so..... and I'm as bad as everyone. My 2 valves have been closed for 10 yrs- I should take my advice!
As far as using air pressure, remember the cores were kind of thin & fragile in 1971, they are now 43 years old and are completely unrepairable if they perforate. Ideal would be a good soak in a big pan of hot water but pulling the dash is a chore. Eaaassy does it!
Jimlah,
I should have been more specific. I didn't back flush the core in my cat. It was another vehicle. That being said, the principle should be the same. I do have my cat torn apart in prep for engine and trans remove. So I had to check it out. From the block a hose goes to the tube on the passenger of the tunnel. From there it moves to the drivers side and connects to the valve. It travels through the valve and core then back out on the drivers side and travels through the tunnel in the tube on that side where it connects to the water pump(suction). So I 'd say run the water back through the driver side tube. If you look under the dash you should see the heater core connections on the driver side. They do look small and I'd keep water pressure down. As Bosswrench says, they're old thin & fragile. It may be best to remove it. Hope I got it all right! Sorry if you didn't need all this detail.
Jimlah,
It looks like I have steered you in the wrong direction as far as the tubing in the tunnel is concerned. The post from fordgt has pictures of the tubes actual path through the tunnel. I reversed the path of the tubes. I assumed that the tube on the drivers side started in the back and ended there up front. That doesn't seem to be the fact, sorry to miss-lead you. I'm still learning the ins and outs.
