I'm getting ready to mount a similar mirror on the passenger side. Question is, is there anything under the door skin that I can run into if I move the mirror forward so that the front of the mirror base is about even with or a little behind the 'V' at the leading edge of the front (non) vent window? Any structure under that flat upper area of the doors? Thanks.
...DON'T use 'Sheet Metal Screws'!! Do it the Professional way and use 'Threaded Inserts' also known as 'Nut-Serts'. Then you'll be mounting your mirrors using 'Fine-Threaded' 'Machine Screws' (I used Stainless Steel Allen Heads). The nice thing about 'Thread-Serts' is the MORE you Unfasten and fasten them; the tighter they get!! We used them all the time in repairing aircraft. Another great place for their use, is to replace those two sheetmetal screws that are holding on the 'Top Radiator Cover' to the Chassis. Have fun with it!...
Thanks George,
Yea, I asked my wife to temporalily (sp) hold the mirror in position while I sat in the car and judged the position, she muttered something about me dragging her into drilling a bunch of holes in a perfectly good car. I've got plenty of good Scotts blue tape left over from the home office rebuild last month, have a good center punch, and a drawer full of new, sharp bits. I'll make sure I have my Depends on when I begin... The uncertainty is part of the experiance that keeps sucking us in.,
LOL
Take care
john
...When drilling be very cautious of letting up on the pressure when the drill bit is ABOUT to break through the Sheetmetal; you don't want to 'Slam' the Drill CHUCK into the doorsill or the window trim strip. Where to find the 'Nut-Serts'?? Very good question!!! As I have been looking for them recently and have had NO luck! They use to sell them at 'J.C. Whitney' (cataloge), also 'Orchard supply Hardware'. NO longer available. I may try 'Eastwood' autobody repair tools, or have to seek out an Aircraft Tool Supply House. I still have the installation tool, but the individual 'serts' are going to take a 'Hunt' to find them. They are worth the effort! Good-Luck to US!...
Whoa! I didn't realize that the photo makes it look so close. Here's another shot of the mirror. It is actually angled closer than it has to be because I have a "fisheye" convex mirror on it which changes the mirrors base angle. It would actually point further away from the car if the convex mirror wasn't there. There is a wide range of view adjustability from this mounting position. It was already on the car when I bought it.
  • DSC00122
...you want to move the mirror farther forward so the point of the mirror mount, aligns with the point at the lower corner of the quarter window. In this position, the 'Full Mirror' will be in the 'line of sight', through that window, of the drivers' EyE. It works on My Cat!...
