Hi there i need to reattach id tags, engine number and smog plate in engine bay, and id on driver rear pillar. can anyone please prove photos with measurement to locate these plates in the engine bay.
Also the tag for the door pillar i purchased a new one from one of the vendors and it's considerably larger than the one that it's replacing so holes don't match and can't re drill as they will catch existing holes. does anyone make an original sized plate for a 1972 p car.
also is there a plate that shows the zf number to see if all numbers in the car are matching.
cheers in advance. cj
Cheers Rocky, yes would have been easy to have used original holes but my first panel guy was nice enough to weld them all up without discussing.
I have the holes for the door pillar but the original tag is damaged and i need to replace, but unfortunately the one i have purchased is larger than the one you are measuring and as such would make a mess to attach. the ruler was just what i was hoping for thanks. cj
