Anyone have any ideas on what is a good harmonic balancer to put on a 1972 pantera, also does anyone have any suggestion on spark plugs? what type, part numbers? to use. thanks, George.
Balancers are dime a dozen. There are many options from stock to certified racing models. The right one depends on your wallet and motor. These things fail over time so re-using a 30 year old balancer is not worth the risk. Either purchase a stock replacement or one of the many aftermarket options avialable.
