Inop right tail lamp and front and rear side markers.
Guest
The right rear tail lamp plus both side markers on the right side of the vehicle are inoperative. The bulbs are all fine and they are on different fuses which are OK. Do they share a common ground?
There are 2 grounds involved: each tail light has a separate ground that may need to be unbolted, wire brushed & reattached. But more likely is the central ground point under the dash, behind the gauge panel on the console. Above the tach is a stud to which is connected maybe 6 or 8 separate ground wires. Condensate or a leaky windshield causes corrosion. Unbolt the ground, wire brush all the connections clean and re-tighten. Loose or corroded wires here causes weird and unpredictable electrical problems. Good luck-
Jack is right.I had a similar problem and he told me that it was a ground .He was right. The ground behind the taillights(the sockets themselves)was coroded.the car was apart for paint and when i put it together, the brake lights and turn signals didn't work when the headlights were on.Fine when the headlights were off.I cleaned the ground and it worked perfect. Thanks again Jack
quote:Originally posted by r mccall: Jack is right.I had a similar problem and he told me that it was a ground .He was right. The ground behind the taillights(the sockets themselves)was coroded.the car was apart for paint and when i put it together, the brake lights and turn signals didn't work when the headlights were on.Fine when the headlights were off.I cleaned the ground and it worked perfect. Thanks again Jack
Same thing is happening on my car except I've got a blown fuse. Can it still be a bad ground if the fuse is shorting out? I doubt it but I'm not sure... Thanks!!
Well it's not exactly the same. For me it's the left-rear tail light and the right front parking light. Turn signals (front and back) along with the brake light work fine.
quote:Originally posted by LAM: The right rear tail lamp plus both side markers on the right side of the vehicle are inoperative. The bulbs are all fine and they are on different fuses which are OK. Do they share a common ground?
