Originally posted by Tom@Seal Beach:
You have to cut the old brace out and then just loosen two large nuts that secure the front lower ARM suspension pickup on each side...then you slip in the brace and tighten down the bolts. You probably need a sawzall...if you won't use it again, you could pickup a cheap one at Harbor Freight or Costco.
It's a pretty easy job....if you can do an oil pan gasket you can do this. Send me your email address and I'll send you a picture of the brace so you can see it. Also you may want to change out the old Emergency brake bracket also...both are less than $200. I can send you pictures of both.
Yes! Please do send photo's.
It sounds like a job I could tackle. I just don't have access welding or torch set. However I am the Charlie Daniels of the Sawzall!
carrera_c4@yahoo.com
Thanks for all the input guys!
