Following parts are oem from 1971 17,000 mile car.Feel free to make offers.
Set frt/rear brake calipers.
Set frt/rear rotors.
Rear axles.
Steering wheel(needs pad).
Frt shocks with springs and spacers.
Rear camber bar(powdered coated).
Following parts are new:
Carrera aluminum bodied coilover shocks $700.00
Pantera Performance adjustable rear a-arms $580
Runner, the shocks have adjustable ride height and compression adjustment. The damper is part #6257 2.5 diameter springs frt rate 450 lbs rear 550 lbs. They are new bought from local oval track shop.
I do not have a digital camera for picture of upper control arm.If you go to Mike Daly's pantera site and look under pantera's under construction look at Kelly Coffields car, their is a picture.
danno
