I have trouble with heel and toe during shifting because of the pedal positions in my Pantera. The gas pedal is very deep in comparison to the brake. Any way to make some adjustments so I can more easily heel/toe?
There are pedal-stop adjustments under your dashboard that can be used. Or, JC Whitney used to sell a clamp-on gas pedal plate that raised the surface 1-1/2" Remember the ZF transaxle with its balk-ring synchronizers doesn't lend itself to speed-shifting.
