Hi everybody,
I would like to know if I can put the Pertronix distributor (# d132701 female terminals cap) on my car ?
http://www.pertronix.com/new_products/ignition_press/ig_pg42.htm
For the ignitor kit we have to choose between a dual or a single point and with or without vacuum.
But for the complete distributor there is no choice (only with or without vacuum).
Did someone put it on his Pantera ?
Thanks.
If it won't work, you might consider just converting your point distributor to a pointless conversion kit...Pertronix makes them and it just fits into your existing stock distributor.
Crane makes a pointless conversion kit that has a rev limiter built in, I was it on either Jeggs or Summits website. I also read on a Camaro forum some Chevy guru using these kits and changing out the coils to high output coils...for about $100, that way the existing housing is OEM and the advance curves stay the same...you just get rid of the points. MSD, Accel, Petronix and the other major manufactures make these.
I posted a question to the other Pantera forum and four people said they had used this type of conversion and they work great and no failure for 8-10 years so far.
Thanks Tom,
I ask this question because my stock distributor is equiped with an old (out of order) electronic ignition kit. There's no more breaker plate in.
I ask pertronix and for the ignitor (I or II) I need the point plate. So...
I would like to keep my car with a stock dual point motorcraft. But prices (on ebay) are prohibitive.
Thanks again Tom.
