On the rear carrier there are two pins that hold the washers for the lower support shaft. My car has one left, should I re-drill and replace the pins?
Also I tried to push out the old bushings for the support shaft in the carrier with a one inch washer with flats ground on them for instalation, but the washer went conical. I was thinking of haveing hardened washers made. Any other ideas?
