Originally posted by gman:
my second radiator fan dose not come on.the fan works.do i change the relay or the sensor in the radiator?this is all original equipment.thanks!
I did jump the fan and it does work.I did open up relay and press down on points and the fan came on.Looking down at lower radiator area where the sensor is located,may have small leak .What is the best way to check or remove sensor or should I just remove radiator and it repaired and replace sensors?thanks
