I have a 74 Pantera with a Phoenix radiator in it with Gary Hall's front mounted AC condencer mounted on it.It's a neat package and works well. I would like to purchase a Fluidyne alum radiator and install it in its place. My question is, are the dimensions about the same for each of the radiator's? I don't have much room on the sides, front or rear.The left side touches the head light mechanism, the back side just clears the cooling fans and with the condencer in front I can't lay the radiator down. Any info would be helpful. Thanks for you're time...
The Phoenix radiator is basically TWO radiators ganged together, so its much thicker than the Fluidyne unit. Fluidyne makes a specific radiator for the Pantera, available as a drop-in from all the Pantera parts vendors. In addition, consider using a different A/C condenser than the stock unit, which is quite bulky. My own system uses an aluminum condenser from a mid-80s Toyota pickup truck and is only 1-1/2" thick with the same length & width. The combination of the thinner Fluidyne radiator and the Toyota condenser lays down just fine using stock fasteners. You may need to do some metal-moving up front (I used a small hydraulic jack and a ball-peen hammer) but I assure you, the work is minimal, and the weight savings over your present system will be on the order of 40 lbs, with as-good or better performance in cooling engine and driver!
