Call precison performance. I know they can provide a replacement. They have a stainless steel model.
Removal and replacement is another problem. You have to remove the complete pedal box to gain enough access to slide the rod over. This means a whole lot of disconnecting of the clutch, brake master etc. Removal of the dash makes it even easier.
If you are looking for a simple job this is not it. Unless you are up for a project, I suggest trying to mickey mouse another solution.
I did this but only part of a total restore.
