Red Loctite and lock wire is the way to go, don't use the old bolts because of the serrated heads or bolts with washers under the head. I am a big fan of Loctite products but if the parts are not clean the thread locker will not work,to do the job right you need to remove the diff and remove the ring gear to clean out all the oil. Lloyd @ RBT
P.S. I use .032 wire,RED Loctite,65 lbs torque.
[This message has been edited by Lloyd Butfoy (edited 09-06-2001).]
Thank you very much Lloyd!
Your suggesting not to re-use the existing Ring bolts?Did you drill new bolts yourself, or did you purchase pre-drilled bolts? Also is there a right and left hand wiring tool and can you recommend some where that I can become educated on how the job should be wired and what the finished product should look like.
Thanks in Advance
Vince
