Selling my MME engine. Started with a std bore 4 bolt main CJ block. Everything has been done top shelf from roller cam and lifters, jesel rockers, studded top to bottom, copper gasket and o-ringed block, CHI heads and intake, custom 750 dp holly, forged scat crank and h-beam rods, Pantera oil pan, build goes on and on.
build including aluminum flywheel centerforce clutch and full electronic ignition.
408 cu.
Built by Mark Mckeown motorsport engineering. $15,699.00
The engine is broken in and dynoes a 680.9 hp at 7304 rpm
so half of new, rounded out to 8k its yours. I have the complete build list, cost and dyno for those who are serious. and yes trading is always an option
509-991-4055
less hp engines although they use the aluminum block start at $17,700. 516 hp. at MME
