I'm in the process of adding a sparkplug wiring loom and found my old wires are cracking around the sparkplug boots. The current wires are MSD but that's all I know about them. The distributor is a large cap duraspark FORD setup. Local autoparts store aren't helpful. Anyone know of a MSD Summit part number that would have the correct wires and be long enough to go through a wiring loom? Too many choices on Summit for the mechanically challenged to pick out the right one from...
thanks Rick
I never asked, but would think PIM or Hall or anyone supporting Panteras would have sets in stock.
Not likely.
Too many variables.
Using looms? Not using looms? Which looms? Running above headers? Under headers? Straight boots? 90 degree boots?
Just buy a generic cut-your-own set, crimp the fittings and get it YOUR way.
