I am running original Koni coilovers (1701's/02's) with the original springs with spacers removed. Does anyone know if ride height can be further lowered with different springs and if so, what springs would I use.
quote:Originally posted by panteralee: I am running original Koni coilovers (1701's/02's) with the original springs with spacers removed. Does anyone know if ride height can be further lowered with different springs and if so, what springs would I use.
Try Pat at http://www.patsauto.com/ I think he does a mod to the shocks to make the lower spring perch adjustable for ride height.
