PI Motorsports has a small supply of new Yokohama tires for the 10 inch Campy rims. The speed rating is 119 mph, I believe. Not the highest, however, when you are faced with shelving the most beautiful rims ever made vs. placing a ceiling on speed until a higher rating is made or found, this is an alternative. Call Jerry at 714-744-1398 for more information. If you are a PI Member, you will receive an additional discount. Dave
