Last week I took out the engine and am removing the original underseal to make it look much neater after painting. having googled engine pics to see what other have done, i see they have removed the metal straps that are spot welded onto the right hand inner wing, ( they hold the wiring loom and the A/C pi[ping) but how are the loom and A/C pipes re routed has anyone some pics please?
Or just install a front mounted condenser.
Looks like you're past the worst part. I was fantastically lucky when I did mine. It came off in huge chunks and left almost no residue. The wiring is rerouted on top of the "rail" in the fender well then behind the tail light recess. It really isn't difficult to figure out once you get into it.
I think I've got a picture of the rerouted AC lines somewhere.
You can route them via the right Wheel Well. Just make shure you put a Sleeve on the Hoses to protect them from Debris. I used a couple of slightly larger hoses that I pulled over the Aircon hoses for protection starting from where they enter the Wheel Well and forward past the Splash Shield. I also moved the Drier Receiver Filter to just in front of the right side Splash Shield where it sits nice and protected.
  • image
