I had to grind the pushrod end corners on the rockers next to the baffles and also bend the baffles some to get them to clear. Not all rockers are the same size so you will need to check yours. Good luck, Forest
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
If you really want to use these another option is a valve cover spacer, available in usually 1/2" that sandwiches betwwen the head and valve cover to raise it.
Thanks guys, I will probably go with the Crane rockers, good to know they fit. Julian, good option on the spacer. I had them on a 351W but was not aware they were availble for a 351C. I will use this as a "plan B".
I’m using the pressure cast aluminum Crane rollers. They might be slightly larger than the machined ones. Can’t imagine you would need a spacer for the covers, they have a lot more room inside than the stock steel covers.
