Has anyone ever tried to vent from the thermostat housing back to the recovery tanks to eliminate the possibility of the air pocket problem permanently?
You wrote “tanks”
The OEM thermostat housing on a Pantera is a long pipe that connects to the surge tank.
can you please clarify exactly what configuration you are pondering?
Larry, my apologies I was thinking incorrectly.
superfluous and erroanous post removed
Hi Joe....
(Based on my experience with the modified cooling system that you are jumping off from, and has been discussed here regularly...)
The way George’s (or Carroll Smith’s) design works is that it bleeds the air that is trapped in the system INITIALLY.
Once you run your car for more than an hour, the system is bled, and there is no additional air introduction into your cooling system.
You will see the system stabilize, by your measurements of the fluid in the overflow tank, and then you’re done for a year until you change your coolant the next time.
sorry for my original confussing post
as stated, venting has been discussed in this sticky
https://pantera.infopop.cc/top...-cooling-system-info
