I'm in the process of putting 2647 back together. Today's question, cooling tubes. Like a dumba$$, I did not write down the routing of all the hoses. Here's what I got so far:
Rear Big tubes:
driver's side: to water pump
passenger side: to bottom of pressure tank
Front Big tubes:
driver's side: upper radiator connection ???
passenger side: lower radiator connection ???
T-stat goes to top of pressure tank
I need help with the smaller ones, the ones with the shut-off valves.
rear small tubes:
driver's side: ???
passenger's side: ???
One of them goes to the top of the block by the t-stat, and the other one goes.....?
Oh, I am installing an edelbrock 8844 water pump
thank you for your help.
John
#2647
