Many years ago I replaced both my window gears with the metal versions. At that time I also replaced all of my window track runners etc. Today, my driver's side window started acting up like the gear was broken. It turned out to be nothing more than that the motor had come loose from the mounting bracket. In order to get them good and tight I dropped the widow regulator down to get at the nuts. That was the easy part.
After re mounting the regulator,the window now binds up. I have tried every possible adjustment of the tracks, regulator mount including various shims with no success. If I even get close with the bolts loose, as soon as I tighten them down the window binds.
I have read old posts that say it is trial and error, but I never had this problem after replacing the old gears .
Any suggestions ?
