the only american car that has the same splines as the pantera is the rear wiper arm from a jeep cherroke[88to96].If yours park on the left side they will slip right on if they park on the right you will modify by drilling out the rivet and turning over solid steel shaft in the body, alittle bit of bending a new revit and thats it.Also you can try www.carbuildersolution they are in the UK,they might be able to help
