I am in the process of wiring my engine management system into the Pantera and had a couple questions. First a little background information. The engine is a modular 5.4L DOHC with an Independant Runner FI Intake. I am using ACCEL GEN 7 DFI for engine management. Here are my questions.
I need a source wire for switched 12v in start/run can I use the old pink coil wire, alternatives?
The GEN 7 also controls the a/c clutch relay. There is 1 wire that is supposed to go to the a/c relay how do I wire it to the a/c relay? I think it replaces the red 12v wire from fuse 7, am I correct?
