My mechanic thinks he read something about a special transaxle fluid for the ZF. Car sat around for a long time, so the fluid needs to be changed. Any suggestions?
The ZF manual specifies 'low phosphorus oil, 80 wt'. In addition, since this is a clutch type limited slip differential, it needs a 'posi-type' oil or additive. I've been using 75W90 posi- type gear lube for some years with no adverse effects.
