Hi, Does anyone know of a ZF builder in Columbus, OHIO area ? Also, where can I find used parts for ZF? I do not know the extent of damage as the tran is still in the car, 5th gear got stuck followed by grinding noise. I suspect the ring gear bolt came loose. Will it need a total rebuilt or just certain gears need to be replaced? Any suggestions on where to have this work done. I will appreciate the advise.
Regards
SHAH
shahcool7@yahoo.com
