The most common factory size wheels are 15x7 and 15x8. There are also the very rare and expensive 15x10. All these will fit your narrow body car. I have never seen a 9" campy...
And to absolutely verify, all Campys were stamped with the size in the rim, visible with tires mounted. Unless someone polished the stamps away or they got filled with paint.
When you block a person, they can no longer invite you to a private message or post to your profile wall. Replies and comments they make will be collapsed/hidden by default. Finally, you'll never receive email notifications about content they create or likes they designate for your content.
Note: if you proceed, you will no longer be following .
