While in the process of removing and cleaning up the front A-arms for new busings, I notcied that the bushing/pivot point on one end of the driver's upper looked to be rather off-center to the A-arm on the horizontal (couldn't) reduce photo enough to post). Held on the horizontal, the center line of the pivot is at least 1/4" below the center line of the arm, not to mention the welds looks sloppy as H$%#. Contact me direct at mbefthomas@earthlink.net and I can send you the photo directly. Not sure this is an issue, but want to be sure.
Thanks
Mike - 6328
