I have an A/C question that i"m getting different answers from every one I ask,so I'm going stright to the Pantera experts for the answer.I've moved my A/C condenser to the front of the radiator,replaced my compressor to a rotary one and switched over to R-134a.I haved changed the dryer and expantion valve and flushed out the original evaporator under the dash.All the parts needed to do the exchange including the special hoses were purchased from Hall Pantera.My question is according to the diagram in my Pantera Techical book I can hook-up the hoses but not according to the diagram,the hose fittings will not screw into each outher.Bottom line in order to have my A/C work properly should it look exactly like the picture or do I have outher options? Any info would be helpful...Confused??
