Well done Jerry ! Its not on my car ??
Yes it is on the accelerator pedal.(the spacer mounted - angle mounted bracket is to limit the "BRAKE" - corrected .) If my memory serves me correctly The bolt that holds it to the pedal plate is a through bolt (coming through from the trunk side) So it can be added easily (if upsidedown under the dash is considered easy)
If you look closely at mine, it is out of alignment and just catching the accelerator pedal arm. I think that was due to twisting when I started to loosen the bolt.
I thought I was doing something wrong but, it looks like the limiting bolts DO NOT line up with the pedal just like mine. I can tweak it a bit I guess.
Sign In To Reply
