I have the pedal assembly on the bench and trying to get everything adjusted and sorted out prior to installing the unit in the car.  There is a fair amount of adjustability of the pedal angles and I am trying to figure out what is the best setting.  Are these angles good as they are?  Should they be closer or further away from the driver?
F36F4D3F-D14F-4272-B008-E71F60984885_1_201_a
36054F0C-0891-4B04-AF59-8D6F14B89D51_1_201_a
Images (2)
  • F36F4D3F-D14F-4272-B008-E71F60984885_1_201_a
  • 36054F0C-0891-4B04-AF59-8D6F14B89D51_1_201_a
If you don't mind "just talking about this"
I would THINK (don't know) the adjust for in the car is clutch just off the carpet, then set brake to match.  (think I have read where some racers set a stop so standing on the clutch doesn't break something)
So unless there is a documented "in the car" measured angle, setting on the bench is just good practice till in the car
some recomendations about pedal stagger would be good
