Some time ago Bosswrech offered an idea (below) that could help move more air through the engine compartment. Utilizing my original 914, broken plastic spoilers, I’ve fabricated and installed new steel spoilers for my 914 (will know next summer if they made a difference). However, I would like to install something similar to my Pantera. Has anyone tried it since this post? Could you provide pictures of the fabrication and installation?
Thanks!
“Virtually all the air going into the radiator and under the front exhausts into the low pressure area behind the window, after sweeping up past the engine. But if you're feeling experimental, the Porsche 914 had a small strip-spoiler under the car, just at the firewall, that was supposed to swirl air across the bottom of the engine (sealed engine compartment)for cooling. Try it and see if it does anything for you.”
