I found the number 03206 on the driver side of this engine block... How do I properly identify this engine?.. Are there other number locations?.. Thanks...
OK, well.. good news... The plate and engine match up and I pulled the oil pan and it is indeed the original four bolt ... Thanks for your help Larry!...
