Hi Guys, I´m currently developing the physics of the Pantera GT5-S for this great simulator, the Assetto Corsa and, although I have already found most data that I needed, I´m looking forward to accomplish the most accurate and authentic simulation of this car as it´s possible to achieve.
http://www.assettocorsa.net/fo...pantera-gt5-s.17664/
I´d like to ask a few questions:
1- Does anyone knows the CoG Height of this car?
2- Does anyone knows its Steering ratio?
Regarding the suspension, I´ve already coded its suspension geometry and springs rates. What lacks are:
1- (ARBs) Sway bar rates and their motion ratios;
2- Front and Rear suspension travel range or its shocks full stroke;
3- Its rubber bumpstops lengths and rates.
Thanks in advance,
Merry Xmas!
  • Screenshot_pantera_gts_nurburgring_2-12-2014-18-53-3
Depending on how precise you need, the accepted center of gravity of a stock Pantera is about 17" off the ground, and is on the left inside of the depressed area gadget-tray at the back of the console. We say it's approximately where a driver's hip pocket is positioned (in a left-hand-drive car). To my knowledge, all Panteras except the last 25 or 30 Pantera-200s are essentially identical except for track & tread width due to tire variations. More info at (www.tmich.com) under specifications or geometry. BTW, there was an interesting yellow narrow-body Pantera featured on Garagem do Bellote in Sao Paulo earlier this year.
