Hey guys , just put my new guages in and they look pretty good, my question is. does MSD make the harness for my ignition box to my auto meter tach, and does anyone know the part number. Oh, 200 mph Carbon fiber speedo?
parapanteraIf you can't fix it with a hammer.....you have an electrical problem.
Hey, I like that set up! What was required to get the speedo/tach to fit, a "never go back" modification, just a 'lil trim, or they fit as is (like that EVER happens).
When you 're using the beautiful Autometers, is there still an issue with the gauges not being bright enough at night? That alone would be reason enough to change,
