Originally posted by Bruce32751:
i am installing an MSD Blaster coil. The instructions state that a ballast resistor with a rating of 0.8 ohms must be installed. Does the original dual ballast resistor meet this specification or must I install a different ballast resistor.
Do you have the stock ignition and are just replacing the coil, or do you have an upgraded ignition system? Does your car have a factory resister or does it have the resister wire from the ign switch? Once you get this info, you can make a decision. If running MSD their web site has good info and ign forums to check out. I know, I have been there most of the weekend trying to figure out my system. At least I finally got my car to run.
Later,
Angelo
