DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal
bar stock out of your hands so that it smacks you in the chest and flings
your beer across the room, denting the freshly-painted vertical stabilizer
which you had carefully set in the corner where nothing could get to it.
fficeRed Faceffice" />
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light . Also removes fingerprints and
hard-earned calluses from fingers in about the time it takes you to say, "Oh
shit!"
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes
until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your
future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads.
If nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of
intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub you want the bearing race out of.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
you have installed your new brake shoes, trapping the jack handle firmly
under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off
of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps neatly off in bolt holes thereby ending any possible
future use.
BAND SAW: A large stationary power saw primarily used by most shops to cut
good aluminum sheet into smaller pieces that more easily fit into the trash
can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably
has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and
for opening old-style paper-and-tin oil cans and splashing oil on your
shirt; but can also be used, as the name implies, to strip out Phillips
screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket
you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
as a kind of divining rod to locate the most expensive parts adjacent the
object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents
such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially useful for
slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while
yelling "DAMMIT" at the top of your lungs. It is also, most often, the next
tool that you will need.
Originally posted by 1Quik72:
my last DAMMIT tool, was my torque wrench !!!,this past weekend i was torqueing a suspension bolt and the wrench slipped off and smacked me in the mouth gushing blood all over my freshly painted control arm!!! MadYES! i did throw the wrench, and YES ,it was the next tool i needed!..................DAVE
That's awfull Dave! Is the control arm ok?? Big Grin
The woods behind my shop hold the tools I hated and threw! I have a new system, when I go to the parts store I buy myself a nice new tool and chunk a worn one. Instead of buying the complete set... I just get the 1/2 9/16 and 10mm or just the one I need. I have a complete set of Crows feet that I have only used one...once Roll Eyes Looking for tools is a waste of time!
