Can someone please explain to me how to put a battery box in The Pantera. Does it require cuttin through the brace in the front, or is there a differnt way. If possible I would like to see pictures. Thanks
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
I asssume the original question refers to a 'drop' battery box. This should not require cutting any of the structural cross brace under the front trunk, the box should sit between that cross member and the front bulkhead.
