Be aware that all Pantera vendors have used fenders they got off basket-cases etc. Depending on how much work the body guys had to do to the parts, prices will vary. On-line, try [www.panteraparts.com] in the used-part section. This will give you a reference point when you call the others. I'm not aware of anyone else that posts prices for used parts on-line. Also, I would have the replacements in hand before I cut the old stuff away- not everyone cuts in the same areas! Some of the bigger vendors have contracted with shops to make panels new, from scratch.Obviously, fitting either used or new raw panels is not for amateur body-guys! I personally wouldn't even attempt it.
