Originally posted by lastpushbutton:
There are several companies that make 'glass and carbon firber hoods and decks. I think you would find the demand low for doors and fenders. I have seen doors for $900 each in metal. Now a wide body kit might sell. Some times it just ain't worth fixing. I am suprized that Canadian Andrew did not accept the high bid of 14g. A nice body shell is 10 grand, add that to 14g and you have 24 thousand worth of parts to assemble and paint,,.....soooo.... you end up with a 32000$ Pantera... You ca buy one complete for that. Still
There was a company that was making a complete fiberglass Pantera kit to fit on a tube chassis.
I have never seen one in person.
The quote that I read in print was "parts are made as a direct replacement for original Pantera parts".
At the time I was interested in the fiberglass doors. One of the vendors such as PPC was handling them.
If you have ever delt with Dennis at PPC, he is not a guy that can quote specks out of his hat and pull written spec sheets out of a file for you.
It's always, yep I can get that for you, yep it will work, call me back later.
I never called him back later so I never got the door.
The problem with the rear decklid in fiberglass is that it warps pretty bad just sitting in the sun.
I don't know about the front but I would think that it would need steel reinforcing also not to.
