#5891 has problems with it´s brake booster and is looking for replacement.....
As it´s difficult to get the pantera brake booster over here in germany I'd like to learn whether there are cross reference parts from other car brands which can be used in the pantera. Have seen that the 308 Ferrari has a very similar booster but of course Ferrari parts prices are out of this world....
Thks a lot for your comments!
Wolfgang
PS: alternatively I am looking to buy a Pantera brake booster in full working order (see parts wanted forum)
Wolfgang -
Here's a bunch of information I got from the Pantera "Information Summary and Links" spreadsheet.
But I would bet that most of the Pantera Vendors sell a booster solution. You might check with them, too. Good Luck
Chuck
1979-91 Volvo 240s use a 7/8 in (22.5mm), two bolt master cylinder which can be adapted to the Pantera (requires a 2 bolt (mc) to 4 (booster) adapter
Bendix Italia brake booster back half can be mated to Bendix US (Chevy!) front half so a US master cylinder will fit booster rebuilders can do this
Ford Mustang SVO 1 1/8" master cylinder with 3-hole Ford Booster w/Pantera Performance adapter to pedal housing schrader@ev1.net (Kirby)
Ford Mustang SVO 1 1/8" master cylinder with 3-hole Ford Booster (drill new holes in pedal housing) marytaphorn@email.msn.com (marytaphorn)
80s Lincoln Continental Brake Booster (3 bolts thru the footwell aluminum plate vice 4) and a Mustang SVO aluminum 1 1/8 inch Master Cylinder
The OEM Pantera booster has 2 horizontal bolts that are 3-3/8"apart center-tocenter. This the same as most GM master cylinders.
http://www.resleeve.com/ brake booster rebuilding, master and wheel cylinder resleeving KARP'S Power Brakes 66 N. Central Avenue Upland, CA 91786 Tel:909.985.0800
